Upstream O2 required with evolink?
Old Mar 11, 2022 | 11:54 AM
TWinkler's Avatar
Hey everyone,
I apologize if this is a silly question, but when using a pnp link ecu that has a wideband signal from a gauge, is the factory upstream O2 still required? I’m going to be getting a downpipe custom fabricated for my FP Zero, and would like to leave that sensor out to clean up that area of the engine bay.
Old Mar 12, 2022 | 10:13 AM
CDrinkH2O's Avatar
Yep it's required if you want closed loop fueling. Closed loop gives a better idle, good part throttle driveabilty, and the best fuel consumption. On the other hand if this is a race car and you don't care about those things remove it and run open loop.
Old Mar 12, 2022 | 06:11 PM
black_out's Avatar
No link doesn't require the front o2, you can use your wideband for closed loop fueling on link.
Alchem1st
Jun 28, 2016 04:23 PM
sssp
Oct 25, 2010 10:54 AM
GTR2009
Jun 9, 2009 11:58 AM
cladden
Aug 18, 2007 11:38 AM
