New Feature Suggestion..
Ok.. instead of reviving an old thread.. Here's a list of features that would make sense to add to the UTEC.. Of course, would guarantee quite a few new sales just for the anti-stall feature alone..
1) Idle stabilization (see this thread https://www.evolutionm.net/forums/sh...2&page=3&pp=15 ) for a suggestion on how it would work, and what likely causes it..
2) Direct control of the Idle air control motor (and Idle RPM)
3) Control of the A/C compressor (Disengage over a particular RPM and/or TPS)
4) MAF INPUT TRANSLATION.. So people can run aftermarket MAF sensors and have a wiring harness to adapt a GM or Ford Cobra MAF sensor and IAT sensor to the stock wiring harness. (you can use a speed density conversion too, with a conversion harness that just uses an Intake Air temp sensor and your 3Bar Map sensor.)
5) Conversion harness for an aftermarket Boost control solenoid (and translation to make the factory ECU happy) PLEASE do this one.. I'll work with you guys on this one, I really need something that doesnt use a bleed system for boost control..
I have a few others on my list.. But this is all I can think of at this time..
Can a moderator make this particular thread sticky? Please try not to put anything off-topic on this thread, I'd like the TXS Guys to have an easy to reference bit of info..
Our stock turbo is oil and water cooled.. Its not necessary to use a Turbo Timer, just idle for a few seconds before shutting it down.. Its a cool idea, not sure if it would be possible though..
We are trying our best to get things like that to release as soon as possible. We want to get you guys to have fixed fueling software first I am sure you will like it. One step at a time though. MAF transalation
Boost control, did you know that we specialize in boost control
. Jason Hunt... ring a bell?????Thanks,
Jermaine@turboxs.com
www.turboxs.com
malibujack...you are frikin turbo jesus...if i could only understand half of what you say....yeah those things would be awesome...of course i only understand half of what you said haha
LOL I actually am putting together my own "aftermarket" boost solenoid setup.. I'm hoping TXS likes the setup enough to consider offering a version of it (using their own parts of course..)
dont send him anything until the new firmware is released!
as a matter of fact, dont send anyone anything until it is released. actually dont do anything until it is ready! no eating, sleeping, sex, bathroom breaks, NO SOUP FOR YOU!! until you are done!
just kidding (not really)
Jermaine~
