Power Fc D-jetro
I Need The English Instructions To Install Sensors.
Please Can You Explain What I Have To Do Step By Step? |
I'll see if I have some.
Thank You ;)
I don't have mine, but I have a call into the local shop that sells them.
:) Thank You Very Much ;)
Rau, Do you need the instructions for all the sensors? It is a book.
NO ALL CARīS SENSORS, ONLY D-JETRO MANUAL TO INSTALL POWER FC D-JETRO SENSORS (MAP)I CANīT UNDERSTAND JAPANESE OF POWER FC MANUAL .
MY POWER FC D-JETRO CAME FROM JAPAN (RHD) AND MY CAR IS AN EUROPEAN EVO8 LHD. |
The instructions for the sensor installs for the D Jetro are a book. I'll see what I can do to get them to you, but it will take some time.
This is crazy. I just called Apexi in the US and they don't have the instructions in English. I'll see if I can work something out with the shop that has the instructions. |
Thanks.
I Have An Evo7 Rhd Power Fc D-jetro To My Evo8 260 Lhd And Not Start.
Iīm To Trying Without Apexi Sensor, Only Plug Ecu With Standar Maf. I Changed The 8-22 Wires Position But Not Run. Any Idea? Thanks For Your Help. |
I Have To Install The Boost Control Kit With D-jetro.
Please Can You Explain What I Have To Do? Thanks For Your Help. |
I NEED THE EVO7 RHD AND EVO 8 260 LHD ECU DIAGRAM.
CAN ANY ONE SEND ME THIS? rasdel78@hotmail.com MANY THANKS FOR ANY HELP. |
Rau, if you simply run a relay to your fuel pump from either pin 22 or pin 8 it will run. The EVO 7 and EVO 8 fuel pump relay is a bit different and for some reason if you install an EVO 7 unit in an EVO 8 the fuel pump will not turn on. As for the sensors, the map sensor simply plugs in the side. The air temp sensor you can use the stock unit or you can also plug in the new unit and run the wires to the stock wiring harness. Red is signal and black you can simply ground.
OK, BUT I HAVE INTERCHANGED THE 8-22 WIRE POSITION AND IT DONīT START.
THE EUROPEAN EVO8 ECU AND USA ECU ARE DIFERENT. ANY IDEA? |
Thank You Guru, Itīs Truth.
I Can Start My Car With Maf Conected And Read Airt 2.80v Aprox. But Without Maf, Airt Is 4.99v And Canīt Read Temp. I Conected Red With Red/blue And Brown With Black. What Do You Think? THANKS FOR YOUR HELP. |
