-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   Please, help with tps, i'm in total confusion...... (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/152425-please-help-tps-im-total-confusion.html)
giangi Aug 6, 2005 12:00 PM
Hi,
i have a big problem configuring my PFC on a Evo VI, having changed the intake manifold ( a Buschur unit, with Accufab 3" throttle body), and monitoring the voltage with the new TPS ( it has three cables instead of the 4 of the oem unit ) i have about 4 volts with the throttle completely closed, and about 0.4 volts when completely open, but in my opinion i should have opposite values, or not? I tried to invert some connections, not sure of having tried all possible options, but at the moment i haven't had any good result. Trying with the original TPS i have 0.1v closed/4.99v open, but it dos not fit the accufab tb....
Please, help....
Thanks in advance..
Spoolin Spyder Sep 19, 2005 10:09 AM
you need a pinout of the wires for both, then you might have to switch a couple wires if one is increasing rate and the other is decreasing rate which sounds like it is from the voltage values you have.
