-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   Autronic and FIC 1600's (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/224013-autronic-fic-1600s.html)
Ackerson Sep 17, 2006 08:14 PM
I currently have the AEM EMS and I'm going to be switching to the SM4 early next year. I'm using the FIC 1600 injectors, and I don't see those in the Autronic software. Is anybody else using these injectors with their Autronic ecu? How did you set them up?
fatbastard Sep 19, 2006 10:54 PM
this question should be asked in the autronic forums... www.autronic.com
Ackerson Sep 20, 2006 04:57 PM
I do not own the Autronic ecu yet, and therefore do not have access to the Autronic forum.
The numbers on my injectors don't match any of the numbers in the software. There is a 5 ohm 1600cc Bosch injector though, it might be close enough for my needs. Anybody have any advice for me?
Jokeri Sep 21, 2006 04:40 AM
Just pick another injector from the list that has the same ohm´s and flow rating
fatbastard Sep 21, 2006 02:12 PM
when you purchase the autronic, ask your dealer which injector lookup to use.
-franz
Ackerson Sep 21, 2006 05:11 PM
I know how Autronic's customer support works. I've talked to my dealer numerous times, as well as other dealers. They all say that when the time comes they'll help me out. Well I'm not going to buy something that "might" not work. I need to know if my injectors will work or if I need to buy the injectors that my dealer is trying to sell me.
This is the Autronic forum, where people can ask questions about Autronic products. If you're not going to help then please stay out of my thread. Thanks
awdboosted Oct 25, 2006 01:13 PM
We have run 1600cc injectors on the Autronic.
Hic Oct 26, 2006 07:06 AM
any injector will work with sm4 flawlessly. you don't need dealer to tell you that, that is not any secret, in fact, we are proud of that fact!!
EV0-VIII Oct 27, 2006 05:33 AM
Hi sorry to hijack ... but i would like to ask does the autotronic sm4 fit 2005 evo 8 ?
Greg K Oct 27, 2006 05:49 AM
the sm4 is a standalone unit that replaces the ecu and comes with it's own wiring loom. Autronic makes PnP (plug and play) boards that will work in direct replacement of the evo ecu as well.
EV0-VIII Oct 27, 2006 07:03 AM
i have and 05 evo 8 MR does my ecu diagram look like this ?
http://www.roadraceengineering.com/e...-ecuwiring.htm
thanx
Hic Oct 27, 2006 07:44 AM
link is not working, but SM4 works with ANY imaginable combination of engine/ignition/injector. no worries
EV0-VIII Oct 29, 2006 10:05 AM
so my 05 evo 8 has a 4 plug connector like a jap spec evo 7 ?
05 EVO 8 ECU
i got confused when i read this
http://www.lancerregister.com/showth...&highlight=sm4
Hic Oct 30, 2006 07:54 PM
there is no SM4 based PNP for ANY mitsu except for 9. The older models will be adde later, starting with EVO8.
Evo 9 SM4 has 3 connectors.
diablo2184 Feb 6, 2007 04:25 PM
did you ever buy the Autronic?
