-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   Reasons for pulled timing after 5k RPM's? (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/228530-reasons-pulled-timing-after-5k-rpms.html)
Turd Squirter Oct 10, 2006 11:46 PM
What different factors would cause the factory ECU (EcuTek flashed) to pull timing after 5K RPM's? My tuner and I are pulling our hair out here. The car is an '05 VIII with a brand new IX turbo, 264in/272ex cams, Walbro 255lpm, 720cc injectors, MBC @ 22lbs of boost, and a TBE w/test pipe. The car has passed a compression check and leak down test with flying colors. The spark plugs are brand new. What are we missing?
dubbleugly01 Oct 12, 2006 07:27 PM
any way of monitoring fuel pressure? Could be a weak pump or a poor connection in the fuel tank not allowing the pump to supply regulated fuel pressure to the injectors, but something less.
Turd Squirter Oct 12, 2006 09:31 PM
Would poor fuel pressure be reflected in the AFR?
BBYBruno Oct 12, 2006 09:39 PM
Your timing is probably to agressive and you might be knocking after 5k so the stock ecu is pulling timing.
Jeff_Jeske Nov 17, 2006 12:34 PM
Put a splash of race gas in the tank and see if the problem goes away. If so then you are too aggressive on timing.
