-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   First Logs, Evoscan stored DTC's (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/238082-first-logs-evoscan-stored-dtcs.html)
Waz996 Dec 3, 2006 08:46 AM
1 Attachment(s)
Just got my Tactrix and ran EcuFlash with succesful downloads.
My Evoscan also succefully loaded and logged.. Attached first logs on 3rd gear shows almost no knock (count=1 in few instances). Yet I had error codes in the DTC window which varied at each click of the 'Check DTC Present' as follows:
- Injector Circuit (rarely showed)
- Vehicle speed sensor (rarely showed)
- barometric Pressure sensor (rarely showed)
- Knock sensor (almost always)
- Egr sensor (almost always)
The logs show the readings..
Moreover and this is really newbie: Does clicking on 'Clear DTCs' put off the light on the dash? It doesnt in my case, is there any way thru Evoscan to clear the light on the dash?
Your comments greatly appreciated..
Thanks,
Wael
MalibuJack Dec 3, 2006 09:14 AM
Apparently the DTC thing doesn't work with newer Evos. I noticed it always reports different codes that aren't actually there. And clearing it doesn't work.
This works for Evo4Mad's car, so it must be specific to earlier Evos.
Waz996 Dec 4, 2006 04:59 AM
Exactly what i thought MalibuJack! I later logged in Evodxb's car and though his CEL light is off, he showed the same DTC's in random manners..
Maybe i ought to post this to Hamish to give us his point of view...
More comments appreciated!
Wael
MalibuJack Dec 4, 2006 05:34 AM
Definitely let him know.. But I think he was already aware of it since I recall him commenting on it working with his older Evo..
Ultimate CC Dec 4, 2006 06:32 AM
logs look great...
dxbevo9 Dec 4, 2006 03:29 PM
Wazz do you mind posting my logs here in this thread... maybe the tuning guru's can take a look and tell us what they think...and see if our (jdm spec) ecu's have different maps than the USDM spec evos
my car is not flashed..
mods include:
-exhaust mani
-3" dp
-3" catless catback
-works drop in filter
-boost controler set at 21 psi
respect
evo4mad Dec 4, 2006 11:45 PM
It would be nice to see how your car is performing by logging the 02 Sensor and Timing also.
I now have an evo8 ecu in my car, so I am currently programming CEL codes to it. Yes those DTCs only work on Evo4 vehicles.
Waz996 Dec 5, 2006 08:30 AM
I cant upload the stock Dubai ECU ROM, its larger than 150k.. cant remember the site to store files on internet! (photobucket and imageshack only store pictures!)
Wael
