problems with evoscan v0.99
I have a problem with EVOSCAN v0.99.
I'm very disappointed. The logger doesn't work. I get every time the same message: Info: Initializing At 5 baud... Info: Initialization Complete... Info: Waiting for INIT Response... Info: Connection successful... Error: Invalid Evaluation Expression in your Data.xml file or invalid data received. RequestID: 21 Eval Expression: 31,25*0 Error: Unexpected comma : at position 3 Info: Datalogger Ended. What could I do? I had paid for a software, which doesnt work... |
problem solved... metric-system
what do you mean metric - system ?? i just downloaded the software and haven't installed it yet, but in case I run into the same problem.
I believe that the 31,25*0 should have been 31.25*0. Some other countries use "," in place of "." for numeric values, which throws off some applications.
Was this the issue? |
Start-Settings-Control Panel-Regional & Language settings- Customize- Change decimal symbol from (,) coma to (.)
thanks
thanks for the info.. :D .. i feel like a noob now.
