Is this log too lean??? Tuning Guru's please look
1 Attachment(s)
Hey I was just wondering if this log is too lean. I get up to about 18 lbs of boost in this log but I'm supposed to be running up to 23 just left it at around 18 lately because it increases on cold days. this is a 2nd gear pull with a gt35r by the way. it seems like its kind of lean in the lower boost range. but I wanted to see what ya'll think. Please take a look. also. if I were to run 23 lbs of boost I was thinking it would definetly be too lean. But please tell me what ya'll think
im lost :(
What gear is that in?
its a pull in 2nd gear
fireman you seeing something there?
yeah I mean I'm just trying to figure out if its going a little too lean. I was always under the impression that 12.5 afr under WOT is a little on the verge of being too lean
That log is pretty worthless. You didnt even hit 18 lbs of boost til after 7000RPM. Do a log in 3rd gear from 2500 to whatever you run. I go to 7500 myself.
I mean load is load isnt it??? it either has enough fuel or it doesnt??? I am hitting full boost on what I'm running. I only have the MBC turned up to 18 lbs. But I know it would reach it quicker in a higher gear of course. But if thought I'd have to have safe Air fuel ratios in all gears???? But I have been wrong before lol
If ya'll think it would be better for me to go out and do a 3rd or 4th gear pull then I'll do that. I'm kind of new to this but I have seen a few 2nd gear pulls posted on here before.
Originally Posted by Johnboy1065
(Post 4994571)
What..
Originally Posted by cpoevo
(Post 4994589)
Originally Posted by cfdfireman1
(Post 4995307)
..he said. ^^^
You need to log in at least 3rd gear. This is for many reasons ...
1) More data from the longer pull 2) Less relative delay in the AFR reading 3) AFRs get richer in higher gears 4) Knock is more likely in higher gears due to increased physical load |
Originally Posted by TouringBubble
(Post 4995876)
1 Attachment(s)
here is my log for 3rd. this one doesnt look near as lean as the 2nd gear pull. just tell me what ya'll think though if ya will. I'm a paranoid person with all this lol
thanks for looking |
| All times are GMT -7. The time now is 10:22 AM. |
