Can't drive past 20mph
Well I bought a car at the repo auction and I coundnt drive it because it had drivetrain issues. took it apart and it was a bad clutch changed that and drove it for about a mile at 30mph and it bogs and I can barely of past 15mph. It has alot of black smoke. Car has exhaust, cams, cam gears, Perrin fuel rail ,ebg, and a apexi afc, any guidance will be apperciated thanks
Originally Posted by soyer
(Post 7007898)
Not sure if you tried, but I had the same problem, thought my engine was blown. Looked under the car and saw the LICP completely disconnected just hanging, but never had black smoke. I had to keep changing gears just to go 15-20 mph. Reattached, ran like a champ. I always try the cheap fixes first, then move onto the bigger ones. Just check for boost leaks and make sure all clamps are secured would be the first step.
Sounds like it'r unning ultra rich. Will the engine hold an idle? Any mechanical noises; e.g. knocking? Look for disconnected hoses or piping? Pull the spark plugs and check their condition. Any CEL's? O2 sensors OK?
Thanks guys I went under and I did forget to tighten one hose clamp and it cameoff car runs fairly well now thanks again
ok good that your car is running good now, but if your the second owner of the car ill just take it to a shop near you (( performance shop )) and have them do a tune up and a complete check up including boost leak and ,,,,
| All times are GMT -7. The time now is 08:58 AM. |
