logging boost thru LM-2 to evoscan
I wonder is there's a way to log boost thru the LM-2 to evoscan. I was thinking it would be possible to connect the 0-5V output from let's say an aem boost gauge to an analog input of the LM-2 and then log AFR and boost thru the 3840 MTX Series Program Cable to evoscan. Do you guys think that could work? I'm successfully logging AFR to evoscan with the LM-2 now thru the 3840 MTX Series Program Cable.
you can wire it directly to your Evo8 ecu, it has spare 0-5v analogue inputs..
or you can log it via a DLP-IO8 analogue adapter for EvoScan. http://www.evoscan.com/evoscan-gps-o...nel-0-5v-input or you can log it via LM1/LC1 Aux1 |
