RPM's skipping EvoScan 2.9
Hey guys,
I'm hoping someone can help me with this. When ever I log a WOT pull my RPMS repeat, and jump around. Usually around 7-800 RPM skip. I just updated evoscan and that didn't seem to correct it. Any suggestions or things to check in Evoscan would be much appreciated! I'm using a HP Envy running windows 8.1. Example of a log: 5406.25 5468.75 5468.75 5562 5562 5656.25 5656.25 5718.25 5750 Another run: 5250 5343.75 5437 5531 5593 5687.5 5750 5812 5893 |
What you posted looks normal, I don't see it skipping 700-800 RPM.
Yea, looks normal. When these cars start making a lot of power, the engine accelerates quite a bit faster than the what the ECU was ever designed to manage, and you can get some funky stuff like that in the logs.
Am I missing something here?
What's your baud/log rate?
Log looks normal. if you want better resolution log in the next gear up. |
| All times are GMT -7. The time now is 08:50 AM. |
