-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   EVO9 - Revs won't return to idle (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/727556-evo9-revs-wont-return-idle.html)
Grant Apr 15, 2016 07:48 AM
Hi - I have an Evo9 with Cobb Accessport maps for E85 and 91 with 1000cc injectors and some other mods.
I recently had a clutch replaced and ever since the car is behaving strangely. If I rev the motor to 5k rpm or higher to shift, it continues to rev that high when I press the clutch. I need to wait several seconds for the motor to settle back to idle. Any suggestions?
The tune was done 5 years ago and I never had this issue before the clutch replacement, yet my mechanic thinks it's probably the tune causing this rather than a mechanical issue.
Any help greatly appreciated!
desmvp Apr 16, 2016 09:50 PM
Light weight flywheel?
Grant Apr 17, 2016 12:11 PM
Turned out to be just a bad ground strap from battery to chassis. Thanks
