-   General Engine Management / Tuning Forum (https://www.evolutionm.net/forums/general-engine-management-tuning-forum-129/)
-   -   My UTEC is wrong? or it's normal? (https://www.evolutionm.net/forums/general-engine-management-tuning-forum/97573-my-utec-wrong-its-normal.html)
dktop Sep 8, 2004 12:07 AM
Hi, few things problem.....
I installed UTEC and I started my evo... CEL light is ON and it doesn't go off.
is it normal???? or not!!!
and I'm trying to figure out map for my evo.. I read all manual but. I have no idea with how to tune like when put more number for timing, boost, fuel or less number.
Do you guys have some tips? I am so newbie to this thing.
Thanks
my mod:
TURBOXS UTEC with ABC
K&N typhoon intake system
HKS BOV with recirculation
HKS Hi-Power catback
CUSCO oil catch can
instigator Sep 8, 2004 12:58 AM
Sounds like you should take it to a professional.
The CEL light should not be on all the time unless you threw a code and you didn't disable the CEL with the UTEC.
bbbwrx Sep 8, 2004 05:21 AM
Take it to your local auto parts store. They should be able to pull the code for you. After you find out the code looK up what it is or post it here. That will tell you what caused the code at that point we can try to figure out what it is.
Ben
MalibuJack Sep 8, 2004 06:30 AM
Yes, pull the code.. if the UTEC is working fine, you won't get a CEL.. Verify your firmware version (it should be 1.3 or if its an early UTEC 1.2)
Its possible one of your aftermarket parts is complaining (aftermarket exhaust, O2 sensor, Aftermarket intake, etc..) but never triggered the ECU previously.. There's a technical reason behind it.. But the UTEC itself shouldn't trigger any CEL's if its functioning correctly.
dktop Sep 8, 2004 07:13 AM
This means even I didn't disable the CEL with the UTEC, it shouldn't be show CEL light ??
I tried disabled the CEL with the UTEC, it just not show..
EvoPyro Sep 8, 2004 07:26 AM
Did you check all the connections when you put it in. If you tugged on a harness to hard then you might have loosned a wire. Check that and also get that code read it might have nothing to do with the UTEC.
bbbwrx Sep 8, 2004 07:30 AM
If you don't want to go pull the code and think it is the UTEC you can remove the UTEC. Reset the ecu and see if the CEL comes back.
Ben
MalibuJack Sep 8, 2004 06:47 PM
Good point.. you might want to remove the UTEC just to be certain..
dktop Sep 8, 2004 11:09 PM
you know what!
very interesting thing is one day after CEL light doesn't show -_-a
MalibuJack Sep 9, 2004 06:12 AM
There are several things that can trigger a CEL and then go away.. It likely wasn't the UTEC but another component or even your gas cap or something equally unusual..
However even though your CEL went off, the code is still on the ECU, if you want to clear the codes and see if it comes back, remove the battery cables and let the car sit for awhile.. I'm almost certain that the code you got was either an anomoly, or something unrelated to the UTEC.
Spec C Sep 9, 2004 06:23 AM
Just as an aside, If your idle dips too low while the utec is in the car, with the cel disabled or not sometimes it will come on..
It is almost like the utec thinks the car has stalled, this has happened to me while saving maps while sitting idling and also on the highway.. Sometimes it goes away after a few min sometimes it stays on, no code in regestered on the ecu..
dktop Sep 9, 2004 07:12 AM
Oh.. I C.
I will try it ^-^
Thanks
