Apex'i S-AFC II back in stock!!!
Hello Guys,
Just got a shipment of Apex'i S-AFC II in Black and Silver. The third-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter / MAP sensor signal. The S-AFC features a user-definable, twelve-point, adjustable fuel curve that can be set in 250 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. New features also include knock detection, switchable dual maps, and password protection. Price is $324 shipped!!! http://www.gruppe-s.com/Apexi/apx_safc_l.jpg Please give us a call for questions and orders! Thanks Cal gruppe-s 510-498-8400 |
| All times are GMT -7. The time now is 11:22 AM. |
