4g94t BEAST!!!
You're going to have to cut off your T28 flange and weld on a T3 flange, plus probably modify your DP. Shouldn't be too difficult, but sounds less than fun.
I really need to get a welder and learn to weld.
Curious why you chose such a larger compressor when you could very likely achieve similar/the same results with a "standard" T3.
First off, T3 is an efficient turbo yes,but still your not gonna be able to pull the HP number's I'm shooting for with it. The T3/T4E is an extremely efficient Snail,That's why it's such a popular turbo. I get so many comment like: the Power band may not be large enough for the turbo,and most the people have never even put a T3/T4e or a turbo period on there lancer. I have seen a tremendous improvement on the top end with this turbo with Lower boost, then I ever did with the T-28 on higher boost. That's
all it really amounts too,plus the T3/T4E ain't that much more expensive then a T3,and it sucks in more air.
You don't happen to have a compressor map do you? Someeone was asking about them a bit back and I was wanting to do a side-by-side comparison.
I actually think the Larger T3's would suit your peak numbers as is just fine.
Actually to clarify there is different grinds for stage 1 N/A and turbo. They are not the same profiles and whilst the stage 1 N/A cam can be used with a turbo it is not the proper cam to be with a turbo.
As for changing the garret GT-28 turbo which is a 300hp turbo, you can upgrade to the GT-28 350,370 and 400hp turbo without changing anything other than the turbo.
These will still retain the same low boost characteristics of the garret ball bearing turbo's.
