Need help with flanges...
Old Mar 24, 2004 | 11:24 PM
pickleknock's Avatar
aight, i am probably going to use a t-25 turbo stock off a 97 gst. i have read a few things about the mitsu t-25 having a different turbine housing built specifically for use on that car. i am going to modify my kamikaze header to be the turbo manifold, but i just need the correct flange to weld on. what flange do i use and where do i get one?
and if anyone has any other ideas on t-25s and flange combos, let me know, but i would really like to use the t-25.
Old Mar 25, 2004 | 03:44 AM
JVlancer's Avatar
ebay or a custom shop
Old Mar 25, 2004 | 04:06 AM
does not answer my question...
what flange do i use for a t-25 off of a 2nd gen? a regular any day t-25 flange, or is there a special mitsu t-25 flange? i read on HKS's website that the mitsu t-25 housing is different.
Old Mar 25, 2004 | 04:31 AM
liquidlancer's Avatar
id assume it uses a diferent flange in that case
if garret makes the turbo they make the flange and gasket set to go with it i assume
Old Mar 25, 2004 | 12:09 PM
mobius97's Avatar
I can help you man.....NO the HKS mani flanges will not work. They have a squared outlet on the bottom. The stock mitsus use a rounded outlet on the bottom of their exhaust mani with a collar set in on a lip to help with smoother flow onto the exhaust turbine. You need a flange easily answered here : 40 bux plus shipping for the 1 lb item here........
http://linux.forcedperformance.net/m...Code=UNIV-GSFL
The top one is for a stock flange. The bottom is for the squared flange....the kind HK$ uses so you can weld the second flange onto the t25 so that it will mate with the HK$ prebuilt exhaust mani's
Old Mar 25, 2004 | 09:02 PM
so if i am going to use a mitsu t-25, then i need to use the nissan rounded style flange on my custom manifold?
Old Mar 26, 2004 | 09:31 AM
mobius97's Avatar
Yes correct...stock t25 for the dsms have the rounded inlet/outlet flange........
DarkEvo
Nov 19, 2012 10:59 AM
Steve_P
Feb 28, 2010 04:37 PM
kmcconn9
13
Dec 2, 2008 10:37 AM
EvilDylan
Oct 22, 2004 02:30 PM
SinCityEvo
15
Mar 6, 2004 11:10 AM
