Questions about internals 4g94
Old May 26, 2017, 08:39 PM
MTNDEWALLTHEWAY's Avatar
I'm wanting to build the engine to run 15 psi of boost. I know my piston wall is 81.5mm and I am wondering if I buy 81.5mm pistons if they will fit in the block. I have more questions. Just wanting to see if this thread gets going
Old May 28, 2017, 08:37 AM
marcouxa1's Avatar
Of course your pistons will fit if the stock size is 81.5mm and u buy 81.5mm pistons although if your engine has high milage and the cylinder walls are tapered u might want to use 82mm pistons to make sure everything is fresh and perfect. If you ask that question you're probably not a mechanics so are you planning on getting it built for you? I have a full thread on engine internals build on the forum if you want more info here: https://www.evolutionm.net/forums/la...tep-guide.html
marcouxa1
54
Mar 24, 2024 12:18 AM
NoClanSWAT
Lancer Engine Tech
Jan 23, 2013 05:55 AM
lancer2show
Oct 29, 2007 06:33 AM
Talon5spd90
Lancer-Mirage Compatibility Forum
13
Aug 14, 2006 03:20 PM
Talon5spd90
Jun 14, 2005 12:40 PM
Quick Reply: Questions about internals 4g94
