Simon's GTS Turbo Build
ok so now this is the second time writing this i took too long writing it so it logged me out when i went to submit than it never showed up. SO anyways im about to turbo my 4b12 and im just waiting on my last parts to show up in the mail and the weather to clear up. Here is a list of parts i have incase someone wants to do the build themselves.
RA Turbo Kinugawa EVOX WG (.3 bar psi spring ) RA Downpipe RA Manifold RA Piping RA FMIC RA Injectors RA Snorkle for air intake with 3" K&N Air Filter AEM UEGO Wideband Air/Fuel Ratio Gauge Prosports Boost Gauge Glow Shift Oil pressure gauge 34MM Recirculating Dump Valve 4AN hose for oil feed 6AN hoses for coolant lines 8AN hose for oil return all fittings for the hoses Turbo Smart manual boost controller NGK Iridium IX 2668 spark plugs OMNI 3 Bar MAP sensor As for the tune im flashing over a EVOX ROM and have someone etune for me. Im looking to be around 220-240 WHP with 7-8 PSI. I will be installing this as soon as the weather here in the midwest clears up and stops having a bipolar winter. |
I suppose you are prepared for the CEL which will disable your MIVEC?
yup yup i also have been doing some research and i am sure i can enable the mivec im not 100% but i seen on a forums someone telling how they got it to work again or something like that has to deal with something by the cams and you have to get it from a stock EVOX but im not worried about losing mivec
Originally Posted by Simon Pugmire
(Post 10753712)
yeah didnt read that much on it it was more of a skim thing. im not worried about having the mivec right now, i just want to be turbod.
| All times are GMT -7. The time now is 04:39 PM. |
