How do I get to the 4th cylinder rod bearing on my 2008 Mitsubishi Lancer gts?
You'll need remove the oil pan, timing cover, and ladder frame, plus all the engine mounts and accessories that are in the way. It's straight forward, but time consuming.
How do I remove the ladder frame?
I had the engine and transmission out when I did mine. I believe there are about a dozen 8mm bolts going up through to the engine block that hold the ladder frame on. There are also 2-4 that go through the transmission. Your best bet is to find the Service Manual so you know exactly where everything is. PM me and I can send you pics with more detail.
Yes
Can you send me pics to help out? I have the service manual
