hard wiring radar detector
Old Dec 24, 2002 | 07:50 PM
field3's Avatar
Has anyone been able to hard wire a radar detector? If so how and do you have pics?
I have an Escort 8500 and am getting annoyed by the phone cord connection.
Thx!
Old Dec 24, 2002 | 07:55 PM
evo_dan's Avatar
I had mine done at a stereo intall place. Cost me $20.
Old Dec 24, 2002 | 08:01 PM
field3's Avatar
Really?? Was an independent place? Or like a best buy?
Where did they end up mounting it?
Old Dec 24, 2002 | 08:06 PM
NITROHEAD's Avatar
i did mine not thst hard i put it above the rear view mirror looks hidden and badass. I made my own fuse box for my power acc like underglows interior neons radar tv lcd and what not.
Old Dec 24, 2002 | 08:12 PM
evo_dan's Avatar
It was an independent shop. Had it mounted bottom center of the windshield. The wiring disappears into the dash never to be seen again.
Old Apr 30, 2003 | 01:28 PM
fastnoypi's Avatar
Does anyone know the pin outs on the RJ-11 plug? would be helpful for mounting anywhere in the car. cheap too..since it is really phone cord.
Old Jul 1, 2003 | 07:43 PM
Capt_Crunch's Avatar
What's the best circuit to tap into for hardwiring a Escort 8500. I have a vampire tap, so as not to cut anywires and void the warranty. I was thinking of using the cig lighter circuit?
Old Jul 2, 2003 | 01:14 AM
CooperAWD's Avatar
passport/escort makes hard wire kits for the 8500 etc... they even have one that has the light/alert/mute-button thing that is found on the cig-plug.
the one w/ the warning light is 29.99 and the normal one is 10 dollars... but i figure its just a basic phone cord so you could buy one and wire it yourself for like 3 bucks or less.
https://www.escortradar.com/cp/cgi-b...main_cat&ref=7
Personally i would wire it at the CD deck... easy place to find/tap either the constant / ign power wire... not to mention its really close to where the radar detector would mount.
Or, if you wanted to mount the detector behind the rearview mirror i would look into tapping a wire at the dome light (there should be a constant 12v there)... you could easily hide the wire by running it under (well, above) the head liner.
the wiring for passport might be a little different so i'll check and reply tomorow... or hell anyone could check by just plugging in the power cord of the radar detector and checking w/ a volt meter... obviously 2 wires are waisted since the cig plug only has power/grnd.
Just my .02, as you can tell i've allready thought about this a bit
