Speakers "POP" during power on...
Old Apr 26, 2007 | 05:28 PM
sykou's Avatar
Like the title says, when i start my car or just turn the radio on sometimes my speakers make a loud popping noise. Sort of the same sound as when you connect a AA battery to the terminals to check the polarity. It doesn't happen all the time but sometimes its loud and sometimes its really soft. I got a 4 channel amp hooked up to the speakers, got another amp hooked up to my sub, and got both the amps running to a 1 farad cap... Has anyone had a problem like this??? Hope you guys can help. Thanks in advance!
Old Apr 26, 2007 | 05:38 PM
badhabit90's Avatar
more info needed.
what kind of amp??
to what speakers is it connected to??
etc...
basically, what it sounds like is either
A. it is connected to the factory CD player and is reminicent of the dreaded turn on pop associated with factory integrated decks.
B. the amplifier doesnt have the "soft start" technology...
Old Apr 26, 2007 | 05:53 PM
sykou's Avatar
I got Alpine Type R Components in the fronts, Alpine Type R Coaxials in the Rears, Hooked up to a Audiobahn A400T 4 Channel Amp running on a Kenwood ??? Headunit. Dunno the model number of hand. If the amp i have doesnt have the "soft start" then is there a way i can add something to stop the popping?
Old Apr 26, 2007 | 05:58 PM
evovin's Avatar
grounded!!!!
Old Apr 26, 2007 | 06:27 PM
radicaledward's Avatar
Originally Posted by evovin
grounded!!!!
+1 ^
Make sure everything is wired and grounded correctly.
Old Apr 26, 2007 | 10:16 PM
Never Satisfied's Avatar
Like was already said. I doubt you have "soft start", easiest way that I have found to fix that (doesn't work on all system, but worth a shot) is to put a 500-1000 ohm resistor in the remote turn on line before it gets to the amps. The most common place I have had to use that trick is with Fords, but occassionally I have used it on other vehicles.
Check the grounds and other connections as well, just to be sure. That is always the first thing that you should do when trying to fix a problem with an aftermarket sound system. Make sure they are tight, and paint free. Also, I'm sure you know, but keep them as short as possible. I think the ground for my amp is like 4 inches long.
Old Apr 27, 2007 | 04:31 AM
Lancer08GTSCVT's Avatar
Get the head unit to turn on before the amp. That will take care of the pop. I do concerts for a hobby. There is a shutdown and start up order you must follow. The amps are always turned on last and shut off first. If you do that you will be in business. Just wire in a kill switch for the amp. Then hit it last when you start the car.
Old Apr 27, 2007 | 09:11 AM
That is exactly what happens when you run from the remote turn on wire from the headunit. Sometimes the delay is not enough, which is where the resistor comes into play. By putting a resistor in line, it will effectively "slow down" the current that is being delivered to the amps. Using a toggle switch could work too, but it is going to be a pain in the *** to have to turn on and off everytime you get in or out of the car.
Old Apr 27, 2007 | 09:26 AM
Never is right a switch might be a little bit of a pain.
Better yet a marketed solution.
http://www.sfxaudio.com/products/dis...p?ProdId=63361
Old Apr 28, 2007 | 02:19 AM
sykou's Avatar
I knew there must be an easy solution! This is just what i was looking for. Thanks I'll update to see if it solved my problem.
Old Apr 28, 2007 | 10:47 AM
If it doesn't work, let me know and I will see if I can come come up with a cheap, easy solution that will work.
Old Apr 28, 2007 | 11:19 AM
Corrected my link
Old Apr 28, 2007 | 05:20 PM
sykou's Avatar
Will do. Thanks a lot!
Old Apr 28, 2007 | 05:21 PM
sykou's Avatar
Originally Posted by Lancer08GTSCVT
Ya i checked it out and im not really fond of paying shipping to here. Being in the middle of the ocean and all...But it does look like a great product, if all else fails then it'll be my last resort.
Old May 10, 2007 | 10:46 AM
URNVS's Avatar
+1 for the resistor!
