Amp not working
Old Jul 27, 2004 | 04:09 PM
B Pars's Avatar
Ok i just re did the entire remote connection. Should I be able to check it at the amp with a volt meter or is their not enough current?
Old Jul 27, 2004 | 04:12 PM
B Pars's Avatar
The light that was on is labeled PROT. I have an Audiobahn A2801X and my cap is and Audiobahn ACAP1P.
Old Jul 27, 2004 | 04:38 PM
dexterdizzle's Avatar
I dont know? Take the cap off and see if everything works without it being installed. It has something to do with the way you wired the cap to your setup. or else the amp wouldnt work
Old Jul 27, 2004 | 04:50 PM
B Pars's Avatar
The amp fired right up.
I have no idea what the hell is going on.
Old Jul 27, 2004 | 04:55 PM
Well here is how i did mine see if it helps
Run battery to + on cap, + on cap to amp then chassis - to - on cap and - on cap to - on amp. And then just check all your other wireing again
Old Jul 27, 2004 | 05:14 PM
B Pars's Avatar
I think the problem is the ground on the cap somehow. I tried chasis to - on cap to - on amp instead of seperately grounding the amp and cap in different places and it still doesnt work. One interesting thing is that when I only had the amp ground terminal connected to the negative on the cap the red light on the back of the amp lit up, with no real ground connection to the chasis for either one. Still getting a headache over this one though...
Old Jul 27, 2004 | 05:52 PM
hmm. try . . . something else. haha this has got me stumped. it doesnt help not being able to see it but still haha
Old Jul 27, 2004 | 07:24 PM
B Pars's Avatar
This is crazy, the volt meter doesn't lie, power going in but no sound coming out, this is some twlight zone ****.
Old Jul 27, 2004 | 07:27 PM
Try and post a pic of your setup when you get a camera. i could prolly tell if i see it than just picturing it ya know. borrow someones if you have to it'd be very helpful
Old Jan 18, 2005 | 08:01 PM
blisi6's Avatar
yo b-pars ive got the same capacitor and an spl 1600 watt amp with two audiobahn exursion subs, my amp turns on for a quick second then turns off and my capscitor stays on for a minute or two then it dies.
looks like we are hooking something up wrong.
Lemme kno if u find a solution.
Old Jan 19, 2005 | 04:31 AM
OZLancerlunatic's Avatar
there is your problem, do - on amp to chassis ground then - on cap to chassis ground, 2 separate grounds. Keep them under 8 inches if possible, long grounds cause feedback and distortion.
EDIT: the PROT light means your amp went into protection because of a bad ground
pignosesr
Northwest Region
Jul 29, 2011 07:54 PM
streetracerkam
Sep 12, 2009 09:36 PM
c900t16
Nov 21, 2007 10:08 AM
sykou
18
May 14, 2007 09:44 AM
virtex
Jun 13, 2005 07:00 AM
