08+lancer stereo wiring diagram
guys need help
there was no dash kit for the 08 lancer about 6 months ago so i cut the factory connector so i could splice to get my aftermarket deck to work... couldnt find the right cables so i custom grounded, +12v,constant and remote.. now i have the dash kit and i was wondering if any one new what wire went to what for example yellow green bdsafasdf = black? someone please help |
most of the time the wire colors are universal.
red = battery yellow = ignition orange = illumination black = ground green, purple, grey, white = speaker (-) above with stripes = speaker (+) or vice versa blue with stripe = remote wire for amp Those are the essential wires for almost ANY head unit install. I don't know if this is what you meant but hope this helps |
no that didnt help not even a little.. i install car stereos.. i need to know mits wiring diagram not the universal one we all know
Originally Posted by bigd31388
(Post 5721663)
o im sorry bro. didnt mean to come off like an a$$. just tryed making things more clear. thank you for helping out tho appreciate it
Hey,
Installed my Kenwood Head Unit/10 CD Changer system today and was unable to get a harness in the UK. I managed to get an 07 Lancer harness plug to connect to the car loom by modifying it somewhat. The speaker wire colours i found were as follows: Front Left Speaker + White/Blue Front Left Speaker - Black/Yellow Front Right Speaker + White/Red Front Right Speaker - Black/Red Rear Left Speaker + Yellow/Blue Rear Left Speaker - Gray/Blue Rear Right Speaker + Yellow/Red Rear Right Speaker - Gray/Red From what i recall, Red/White was permenent live and Yellow/X was ignition live. Just check them with a meter to be sure. The tweaters appear to be on seperate wires so they don't work for me at the moment. Need to take a better look, maybe have to install a crossover onto the front speakers. Hope this helps. James. |
i did it myself with a voltmeter
red is actually the constant which = yellow for aftermarket yellow is the 12v ignition which = red for aftermarket there are two blacks and only one of them are ground so you will have to play with them to figure which one is actually ground.. now this is only for the guys that cut there factory radio wire harness off and are only playing with wires |
(Post 5722549)
I'm trying to find wire diagrams for the amplifier wiring cuz I want to replace the factory amp and sub. I get what you're asking about now cuz I have no idea what each wire is! Why does factory have to be b!tches about wiring?? lol If it were all aftermarket setup like the rest of the world it's be so much easier. |
How about the wires colors for us with the Rockford Premium System?
I talked to metra today, and a harness is in development, but there is no eta for release. |
yeah. that's what I'm asking about.
I'd go and experiment but I don't want to mess around with the harness. |
Yeah, its really pissing me off... Ive got the metra dash kit, my DVD head unit installed and powered up w/my satellite hooked up. Just NO sound... Its a tease.
I have read the schematics in the factory service manual, and have found two remote turn on wires that go from my HU to the factory amp, but am lost after that. Normally i would run an RCA to the amp, but not sure when it comes to stock wires. |
OMFG... After weeks of searching i believe i may have stumbled upon the answer to all my problems...
http://www.mediafire.com/?n1icjm3xndm The wiring diagram for the 2008 Lancer w/Rockford Fosgate 9 speaker system... Im taking this info to my installer tomorrow, and ill post up to let you know how it goes. |
FOSGATE PUNCH® 9-SPEAKER AUDIO SYSTEM
Fit Guidefe- Radiofe- Mountingfe- DIN Fitbfge DIN Fit Kitbfge Openingsfe- Radio Depth 7.75 (INCHES) Standard Radio Opening CORPORATE PANEL Radio Picture Click to view image Optional Radio Opening 1 CORPORATE DOUBLE DIN Audiofe- Radio Informationfe- Radio Optionsfe- Radio Security YES Speed Control Volume NO Steering Controls YES Satellite Radio OPTIONAL OE Satellite Brand SIRIUS® Batteryfe- Wire Color RED/WHITE Polarity (+) Location RADIO HARNESS Pin # 20 PIN PLUG PIN 10 Accessoryfe- Wire Color YELLOW Polarity (+) Location RADIO HARNESS Pin # 20 PIN PLUG PIN 1 Groundfe- Wire Color BLACK Polarity (-) Location RADIO HARNESS Pin # 20 PIN PLUG PIN 20 Dimmerfe- Wire Color GREEN/WHITE Polarity (+) Location RADIO HARNESS Pin # 20 PIN PLUG PIN 9 Power Antennafe- Wire Color PINK Polarity (+) Location RADIO HARNESS Pin # 20 PIN PLUG PIN 14 Amp Turn Onfe- Note THIS VEHICLE USES CAN DATA SYSTEM TO TURN THE AMPLIFIER ON |
Radio Outputfe-
Speaker 1fe- Front Leftfe- Wire (+)fe- Wire Color WHITE Pin # 28 Note THESE WIRES SUPPLY THE AUDIO SIGNAL TO THE AMPLIFIER Wire (-)fe- Wire Color BLACK Pin # 38 Front Rightfe- Wire (+)fe- Wire Color RED Pin # 26 Wire (-)fe- Wire Color GREEN Pin # 36 Steering Controlsfe- Steering Controls 1fe- Wire Color BLUE Polarity (+) Location RADIO HARNESS Pin # 22 Note THIS WIRE SUPPLYS A REFERENCE VOLTAGE TO THE STEERING CONTROLS Steering Controls 2fe- Wire Color BLACK Polarity (+) Location RADIO HARNESS Pin # 32 Note THIS WIRE USES RESISTANCE ON THE REFERENCE WIRE TO CONTROL RADIO FUNCTIONS Vehiclefe- Integrationfe- Radiofe- Electrical Constraints NONE Physical Constraints NONE Solution NONE Productsfe- Metra Electronics Corp.fe- 99-7011 MITSUBISHI LANCER 2008 |
so how did the install go?
there isn't info about the amp harness, which kinda sucks but it's good info none the less. |
