Incressing the Load in ECUFlash?
Old May 5, 2009 | 09:54 AM
Live4Redline's Avatar
Reposted here in the hopes i might get some feedback..
https://www.evolutionm.net/forums/ec...-na-boost.html
I'm not talking about tuning the car because i already know how to do that but i want to know if i increase the number of cells in the Load axis and then correct the corresponding fields is there anything else i need to change for it to read the new cells?
I increased the Fuel and Ignition maps so that it can read past 100 load and can tune into boost.
Is there anything else that needs to be adjusted? or is it just that simple. I'm unsure and just wanted to check with someone who's done it.
Old May 5, 2009 | 06:18 PM
senate6268's Avatar
You can't increase or decrease the number of values in the x- and y-axis. You can only re-scale the values. There's a few people on the forum, including myself, that have done this. There's no need to scale higher than 120-130 at most. Our ECUs don't register load like the Evo ECUs do and the loads are interpreted as lower values.
Old May 6, 2009 | 12:52 AM
Do you mean that i can't or shouldn't increase the number of values in the X & Y axis's? Because i was able to increase it already, i just haven't tested to see if it'll read into them yet.
I can understand not needing as much load as the evo but could you explain a little deeper into how the load past 100 is interpreted for me. I don't quite fully understand.
And thanks for the reply,
Old May 6, 2009 | 12:33 PM
And just wandering... when you rescaled it what did it look like in the end. What numbers did you get rid of and replace with?
Old May 6, 2009 | 08:51 PM
senate6268's Avatar
Most of us increased to a higher interval at the lower load values in order to increase the higher load values. Here's what my values are for my fuel maps:
15 25 40 55 70 80 90 100 110 120
You cannot increase or decrease the amount of values from 10 for the x-axis. There is code in the ROM that states what size each table in the map is.
Old May 6, 2009 | 09:47 PM
Well that makes since... cool, thanks for the heads up then.
chaotichoax
Sep 7, 2015 07:41 PM
03whitegsr
Sep 21, 2012 03:54 PM
Live4Redline
May 13, 2009 07:57 AM
r3compile
Sep 21, 2008 07:30 AM
