4G69 throttle body swap, NEED HELP!
Old Jan 8, 2012 | 10:20 AM
nick9g4b1's Avatar
So far, I'm happy with the 4G69 throttle body swap. Everything seems to be running alright with one exception. Yesterday evening on the highway, I look down at my speedometer and noticed it was reading at, around 80mph; I felt as if I'm actually going 60-65mph. Today, I'm driving down my street, 1st gear/ around 2-2,500k rpm and I reach 20-30mph real fast, while I'm actually only going about 10-15mph. Can anyone help me with this problem, what do I need to do? Re-calibrate it? Go to dealership?
PROBLEM SOLVED, THANKS GUYS!
Old Jan 8, 2012 | 12:28 PM
LiX's Avatar
LiX
Throttle body doesn't have anything related to your speed sensor. Did you change the tires with different size? That can explain your issue.
Old Jan 8, 2012 | 07:30 PM
masafina's Avatar
Is not your throttle body
Old Jan 8, 2012 | 08:12 PM
nick9g4b1's Avatar
Correct, the throttle body has nothing to do with the speed sensor, but everything was good until I installed the 4G69. Right now, I have my stock wheels on but during the summer, I use different wheels. Even when I use those wheels, there's no problem. So, I have no idea what went wrong? Can a tune fix this? What tuner should I go with? My buddy who gets his done is $300 for the first time and anything after that is free. What are some good specs I should set my car at ect? LMK. Thanks!
All I have on the car now is...
...oem wheels, rrm aluminum crank pulley, injen cai, injen full exhaust, tein springs, twm short shifter.
Old Jun 29, 2012 | 07:10 AM
melficersx's Avatar
How did you end up fixing the problem?? Thanks
Diavlo
28
Dec 29, 2024 05:49 PM
Diavlo
Jun 19, 2017 03:24 PM
doncarbone
157
Oct 8, 2015 01:28 PM
doncarbone
12
Apr 26, 2014 09:37 PM
nick9g4b1
Lancer Engine Tech
Dec 29, 2011 05:38 PM
