Idle Air Control issues
Old May 14, 2013 | 06:23 PM
nuclearbanana03's Avatar
Hi all, ive been having issues with my idle air control (iac) I have an 03 oz with cai, and piggyback chip. I ran the code reader thru it and it came up with "engine rpms higher than expected, also got a low voltage to crank sensor. The idle pulses about 500-800 rpms at a stand still. Ive bought a new iac sensor and replaced the entire throttle body with a new one. Other issues (related? Not sure) car bogs down at lower rpms until I really step on it.
Old May 14, 2013 | 09:08 PM
03lances's Avatar
When you say new TB do you mean brand new or used (new to you)? And the iac is the black circular motor below your intake tube this is what you replaced correct? Usually the issues you are having is caused by a bad or dirty throttle body so if you got a used one make sure you cleaned everything on it really well. If you bought brand new then I would start with cleaning your maf and run some injector cleaner through.
Old May 15, 2013 | 10:19 AM
Its a used TB less than 75k on it, cleaned it up really well. Yes that is the iac that I got. Is there any special way to clean the maf?
Old May 15, 2013 | 10:51 AM
Green_Bandit's Avatar
Just use MAF cleaner. Not carb cleaner, MAF cleaner. Take off the air box and inspect it, if everything looks good spray it down while it's cool. NO TOUCHING!
Edit: a little seafoam through the gas tank and the vacuum to the manifold by way of the brake booster line wouldn't hurt also.
Old May 16, 2013 | 10:23 AM
Ok cleaned maf runs a lot better but not quite 100%. Gunna clean it again and hit the throttle body. Anyone use maf cleaner on the iac?
Old May 16, 2013 | 12:38 PM
03lances's Avatar
As far as the iac goes you can use the maf cleaner on it. I would just spray some on a cloth and wipe the sealing surface of the iac and if you haven't already clean out the channel really well that the iac uses
Old May 30, 2013 | 09:35 AM
Broke4speed's Avatar
What exactly is the piggyback chip? If it's a little device you wire in, and cost less than $50...that's what's causing your idle surge.
Old May 30, 2013 | 10:57 AM
Good point. I totally overlooked that. Even if he had the rrm piggy a mistake in wiring will cause a bunch of silliness.
Old May 31, 2013 | 10:34 PM
Its a Gforce chip. I did get the bright idea to unplug it and I cleaned the maf and ran seafoam thru it ran alot better, Then the intake valve guides in cylinder 1 decided they wanted to shatter. So tomorrow I get to go pick up a newer engine I found for 300 bucks, maybe that will solve the idle issue lol.
Old Jun 3, 2013 | 06:24 AM
Pure garbage, and if you don't remove it, your issues will never go away.
http://www.gforcechips.com/mitsubishilancer.aspx
Ripoff testimony:
http://www.ripoffreport.com/r/gforce...scammer-794770
The best proof:
http://gforcechipscam.com/
Old Jun 3, 2013 | 06:39 AM
Intake valve guides shattered? What did you do to cause that?
Also, this eBay & knock off route you're going. Don't do that. It's not a good look. Save the money, get some quality parts or don't and save your money for a better car.
Old Jun 3, 2013 | 07:01 AM
My guess would be constant redlining, burnouts, and general abuse.
Old Jun 4, 2013 | 04:08 PM
Ya that chip went in the trash where it belongs. As for the guides. That would be due to a timing belt gone bad before I bought the car. bent some valves. I replaced them but at the time the guides looked good. But yes I've learned my lesson on ebay crap
Old Jun 5, 2013 | 06:26 AM
Good job!
The first step to a good car, is good parts .
383firstgen
Jul 10, 2012 08:42 AM
newimportowner
Dec 12, 2011 12:54 PM
fast3voviii
Oct 28, 2011 09:17 PM
SW20Mike
Aug 24, 2011 05:40 PM
mitchroxz
Mar 26, 2010 06:33 AM
