04-06 USDM Ralliart Tuning process please.
Hi all,
I am usually over in the EVO ECUFlash tuning forums for the 8/9, and have tuned several EVO's and a few WRX/STI's.
I currently have a guy wanting help in tuning his 04/05 USDM Ralliart. I am utilizing the Tactrix 2.0, and using the deffinition files I found in another thread on this section of the forum.
However, loading the into flash, and utilizing the ECU setting within ECUFlash to the 04RA ecu, I get this:
I select the highlighted ecu, and then try a read.
Flahs code says it utilizes this base metadata:
It then errors out.
Here is what I read over on the EVOScan forum:
http://evoscan.com/index.php?option=...ms%2Flancerxml
and it looks like this is the way they say to flash it...
Please tell me there is another way to do this?
Thanks in advance.
using metadata XML ID read_mitsum32176f4 from file C:/Tuning Tools/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32176f4.xml
Thanks in advance.
Did you try flashing it with the ecu connected in the car?I don't know what rallairts use to tune maybe you should go in the ralliart tuning section....if it was a 2.0L ES/LS/OZ i could of helped but not for a ralliart sorry :/
Do you know if this can be used for the 04-06 non ralliart lancer with the 4g94? it would make life so much easier to live tune!!!
I know you guys use Evo ROMs for turbocharging, but if you want to just tune the engine without boosting, is there support for that?
There are already tuning options for the 4g94, there is very little for the 4g69...hackish chose to support the 4g69 lancer, as well as the 4g eclipse for the very reason that there was no support for it...
nlp187
Jul 8, 2012 10:32 PM
Blue Bullet
43
Mar 27, 2011 06:40 PM
Boost3dxEvO
Aug 22, 2009 06:47 AM
mlevo
Apr 25, 2005 06:48 AM
