Dedicated N/A ROM tuning thread - Page 19 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
Old Jan 12, 2019, 03:47 AM
  #271
Sit
[QUOTE = jajk; 11856354] Можете ли вы опубликовать журнал WOT на 2-й передаче с 2000 - максимальные обороты в минуту, показывающие фактическое время мивека и зажигания на вашей лучшей мелодии? [/ QUOTE]
Yes, but later, we now have snow. By the way gasoline with an octane rating of 95
I do all the logs on the 3 gear. I can post them
Sit is offline
Old Jan 12, 2019, 04:43 AM
  #272
Sit, 95 octane an -20C temps? Can you run that timing in summer? Do you reduce knock sensor sensitivity too?
If you have a 3rd gear WOT log with mivec actuals, ign timing etc. would be nice to see. Problem with showing mivec maps is they can bear no resemblance to what is actually happening.
I will publish the method to actually calibrate the mivecs at some later date.......maybe.... another free lunch for the a$$hole "pro tuners"
I peak out at 23 degrees timing @ 6750 with 91 octane and 31C with 80% humidity at the moment....cold air intake doesn't reach all the way to Russia
jajk is offline
Old Jan 13, 2019, 06:35 AM
  #273
Sit
Stock miveck with tune AFR and timing
Sit is offline
Old Jan 13, 2019, 09:26 AM
  #274
Originally Posted by sit View Post
stock miveck with tune afr and timing
Лучше логи кноков и октана покажи с такими углами)))) А залить стереть адаптации и пронатьпна стенде это ничего не показывает.
greder is offline
Old Today, 01:47 PM
  #275
Sit
jajk ,
как вы думаете, какой ROM лучше для нас, 51420011 , 53770002 or 53770004 ??? Many tuners from Russia for some reason prefer Rom Outlander XL 51420011
Sit is offline
Old Today, 04:42 PM
  #276
Sit, tuners prefer whatever they are familiar with or have a definition for.
I know these ROMs quite well and can say that the earlier ROMs all the way to the most recent (2017), share the same basic coding. What changes is the refinement of the tune is improved over the years or features are utilized that were always available but ignored in early tunes.
The 53770002/4 ROM falls in the category of a basic tuned ROM which is easy for tuners but not necessarily better than 59780002 for instance. If you know how to manipulate added features of later ROMs, like controlled throttle v RPM maximum openings or speed related limits etc. then the later ROMs are superior. If you do not know, the later ROMs will give you a headache and slower car.... Some tuner will use 4B11 ROMs for 4B12 to avoid dealing with torque limiting (ign retard) and EGR etc. in 4B12 ROMs. 51420011 is useful because Russia did not get any 4B12 Lancer to take ROM from (not trusted with more power) and this was the first 4B12 ROM easily available.
So the ultimate answer is......the less knowledgeable the tuner, the older the ROM he will use. Unfortunately, everything came from the original breakthrough work of ClubCJ Lancer (Australia of course) and then was messed around with by the evoX community for years. The NA Lancer definition and knowledge is extremely neglected. I have had to trawl my way through mountains of bug ridden defs and code to get a better understanding with the help from a very small core of like-minded enthusiasts...thanks goes out to them.
What is really annoying is the amount of "pro tuners"/software companies that are taking money off suckers for the same old recycled defs from ClubCJ with the tell-tale non-existent "Evap Maps" and tuning maps copied from evos. If you are going to take money off someone - do some work for it you lazy bastards!!!!
jajk is offline
The Following User Says Thank You to jajk For This Useful Post:
mikeooo (Today)
ChangBang
The Loft (Evom Car Talk Corner)
33
Oct 27, 2005 03:34 PM
infin|ty
Evo Tires, Wheels, Brakes & Suspension
12
Oct 5, 2005 06:00 AM
topsnwbrdr
New Off-Topic
35
Apr 13, 2005 10:57 AM
LancerEvoMR
New Off-Topic
May 2, 2004 01:27 AM
SurfguruJon311
EvoM Newbie / FAQs Forum
May 1, 2004 07:43 PM
Quick Reply: Dedicated N/A ROM tuning thread
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
