Dedicated N/A ROM tuning thread
Old Apr 11, 2019, 11:47 PM
  #301
Liked 2 Times in 2 Posts
in xml 52500010 change id to 52500012 and flash with out any changes.
greder is offline
The following users liked this post: greder
Rico8638 (Apr 12, 2019)
Old Apr 12, 2019, 02:00 AM
  #302
Liked 0 Times in 0 Posts
Dear Greder
thanks for your reply.
I will try it.
Thank you!!
Rico8638 is offline
Old Apr 14, 2019, 02:14 AM
  #303
Dear Greder
Today I try it , but the P0500 code still showed....
Do you have other idea to solve it?
Thanks!!
Rico8638 is offline
Old Apr 14, 2019, 03:21 AM
  #304
Maybe need clean throttle body...
and check the wiring from the ecu to the speed sensor
greder is offline
Old Apr 14, 2019, 07:17 AM
  #305
Dear Greder
Thank you for your reply!
I changed the transmission from CVT to 5MT, so my ECU reinstalled the MT transfer program (52500010), which has a speed signal. But the speed signal of my car is use abs signal. So this feature I can't give to the computer. Cause bright p500 fault code.
do you want to check my xml file?
thanks!!
Rico8638 is offline
Old Apr 15, 2019, 03:04 AM
  #306
you need a speed signal from the speed sensor, which is in MT.
greder is offline
Old Apr 16, 2019, 07:01 AM
  #307
Dear Greder
I discussed with my friend , he say my transmission is tight gear ratio , and the transmission did not have the speed sensor , but the ECU need this signal.
Or do you know which ECU ID can support the transmission that no need speed sensor signal?
thanks!!
Rico8638 is offline
Old Apr 18, 2019, 06:38 PM
  #308
Liked 91 Times in 60 Posts
Rico8638 Your vehicle is China market. There are differences that can make rest of world ROMs incompatible.
Your speed signal is coming through the ASC/ABS computer and not from the gearbox so ROM is looking in the wrong place.
Look within China market ROMs for the solution.
jajk is offline
The following users liked this post: jajk
Rico8638 (Apr 19, 2019)
Old Apr 19, 2019, 01:30 AM
  #309
Dear Jajk
My thinking same as you , so I found a ID from China , this weekend I will try to flash it.
The new ID is 54980003 , do you know others ID that also used in the China market?
Thanks!!
Rico8638 is offline
Old Apr 19, 2019, 02:06 AM
  #310
Rico8638 Maybe one of these.....engine size might be wrong in filenames. 54980004 seems to be correct. Not sure what the difference is to 54980003
50140002 2013 4B10 5MT原厂.
50180002 2013 4B11 5MT原厂
54730003 2013 4B12 5MT改装
54980004 2011 4B11 5MT原厂
jajk is offline
Old Apr 19, 2019, 02:27 AM
  #311
Dear Jajk
Thanks for your support!
I have 54980004 rom , but I can not find the xml file for it.
I only have the 54980003 , and I can open it.
Do you have the 54980004 xml ?
thanks!!
Rico8638 is offline
Old Apr 19, 2019, 02:31 AM
  #312
Rico8638 Yes I do. I will PM you with it after I fix up some scaling errors
jajk is offline
Old Apr 19, 2019, 02:35 AM
  #313
Thumbs up
Dear Jajk
Thanks for your great support!!
Rico8638 is offline
Old Apr 19, 2019, 02:48 PM
  #314
Rico8638 This will give you 99% of everything you need to tune. Def may have errors in some of the more obscure maps. Your problem to figure that out
jajk is offline
Old Apr 19, 2019, 09:38 PM
  #315
Dear Jajk
Thank you so much!
I will try it!
Thank you!!
Rico8638 is offline
Quick Reply: Dedicated N/A ROM tuning thread
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
