4b12 4G69 Throttlebody Ecuflash
Old Oct 28, 2024 | 12:32 PM
SANYIIIKA's Avatar
Hello!
I replaced the factory throttle body with a 4G69.
The idling speed bounces back between 1100-1600rpm, sometimes it goes up to 4000rpm on its own.
Does anyone know which table in Ecuflash needs to be modified to make it good? I have already modified a few, but nothing has changed.
Thank you
Old Nov 28, 2024 | 03:15 PM
bumblebee.4G69's Avatar
5 Year Member
The 4G69 throttle body will usually bounce up and down and carry on like a Pork chop when it hasn't been modified. It will usually throw a cell at the same time.if it has been modified it shouldn't do it. There's air flow plausibility maps to be modified in the ECU from memory and few others to get it working as it should. There's a thread I put up a few years ago on the forum that goes thru how to modify the 4G69 TB to work with the CJ lancers
EVOLen
Evo X How Tos / Installations
Oct 12, 2013 01:45 AM
DormantBeast
Jan 18, 2012 05:15 PM
tommysevo9MR
Mar 11, 2011 09:27 AM
lillev23
Nov 29, 2009 01:42 AM
sponners
Oct 2, 2009 08:49 AM
