Tuning 399 maf turbo lancer
i have been trying to get the evo 399 maf to work on my turbo lancer for the past 3 days. it has been an incredible waste of gas time and money as i have gotten NOWHERE.
i have wrx 440s scaled at 412 im not sure if im missing something small or big but i have tried adjusting just about everything with no luck. my idle is bouncing between 13.8-14.3 most of the time. i have adjusted latencies, maf scaling smoothing and injector scaling all with no luck. im going insane. if anyone can help it would be great. i tried 03lances latencies and it made my car idle in the 10s. im about to switch back to the factory maf if i cant get this stupid thing figured out. |
what tuing changes closed loop afrs and vac??
I know I'm bringing up this thread from the dead, but did anyone figure out what to do with the 399 MAF at idle?
I just used the stock MAF scalings and it works fine except on idle. It looks like everyone is having this issue. If you have a solution, please post your scaling here! Thank you! |
Idle is primarily controlled with the injector latencies then shortly afterward, in terms of load and rpm, by the maf smoothing/compensation table.
Typically on larger mafs what you'll see is the first 2 rows of the maf smoothing table to be set at something pretty low like 80%, assuming you have your scaling set to the correct 255 percent scaling. Make sure you adjust your tables scaling to the 255 percent mode if you haven't already the table makes loads more sense in that mode than in the g/s or whatever the old scaling was which is totally incorrect. |
I thought burner figured this out?
I'm interested in results as well considering slatermvp and I are figuring out there's no way to run 10psi with consistent afrs on the auto Lancer rom without a bigger maf. Honestly thinking skipping maf scaling and going SD. |
Originally Posted by Green_Bandit
(Post 10506641)
