I've tried everything! I need help with ECUFlash please guys
Long story short I played with the colors in ECUFlash 1.29a then found out that is a big no-no. Ive been trying to uninstall and re-install 1.29a with the definitions from Senates thread but finding that ECUFlash not finding any Lancer definitions.
Ive created a whole new administrator profile on my computer to get rid of a chance the old files interfering and did a search to delete any old files. After days of me thinking it was my sharing settings (since Im on windows 7) and it not discovering the folder I go out and try a new netbook running Win 7 Premium. But that gave me issues with the cable drivers so I scrapped that idea. Next I took a closer look at Senates thread and saw he updated them to only work with ECUF 1.3 and higher. I have the 1.3u tactrix cable but had to use 1.29a to interface with my car initially when I first started to use ECUF. I just tried ECUF 1.3 and no car interface detected. So I've tried ECUF 1.42.32 1.42.25 1.34 1.30 all with the same result; Nothing Lancer comes up! I see Evo, Eclipse, Subby, Galant, everything else but Lancer! Please help guys. I've been trying to fix this for about 2 weeks. The order that I work in is I download ECUflash download senates definition files and move them to Lancer, then download Roadspikes to Lancer, make sure OpenEcu is shared, and make sure metadata is pointed to>program files/open ecu/metadata Thats what Ive always done. What am I missing? Windows 7, Yes the openecu folder is shared http://i1210.photobucket.com/albums/...gramShared.jpg My definition folder http://i1210.photobucket.com/albums/.../rompict-1.jpg And finally where my Lancer definitions reside http://i1210.photobucket.com/albums/...ncerfolder.jpg Finally what comes up when I try to read from ECU http://i1210.photobucket.com/albums/.../Roadblock.jpg If I get this back working Ill never change the colors again! I promise! :helpme: |
I'm not sure how the colours affected your definitions. But I have faced a similar problem.
Try this: 1. Create a new file outside all the ecuflash files. 2. Put all the XMLs you need to view your ROM in your new file. 3. In the ECUFlash settings, alter the target file for accessing XMLs. 4. ???? 5. Profit. This worked for me. |
I've had issues like this. Uninstall ecuflash/evoscan then goto c:/prog files/ and delete open ecu. Then restart. start ecuflash installer and let it complete then reinstall evoscan and plug the cable when it prompts. Then copy your definitions to C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata instead of changing the folder. You might need to remove the x86 if your not on x64 win 7. Should be good after that. Oh and change user level in ecuflash
Originally Posted by AndyCT9W
(Post 9876226)
what is your user level in ecuflash?? shows us the path ecuflash uses to get to the folders.
I will send you my files in the AM. Sorry bro I have been busy so I haven't had a chance. I don't work tomorrow so I will def have time to send them to you. |
I had to use the 3rd option down on the vehicle lists to get my rom read. My rom (MT lancer) has the same rom size as a AT Lancer so thats what I use to read my rom. Have you tried any of the options yet? I can download and save my rom still but since its not defined I can't look at it :(
Well, What I ended up doing is once again completely uninstalling ECUF and Evoscan. Went back to 1.29a and tried to get a read. Nothing Lancer would come up so I picked Evo 8-9 and after a read it asked me to define from --- and the Lancer definitions would come up.
But RoadSpikes definitions wouldnt come up. I had to make a trip so I couldnt wait any longer I had to redo timing, injector latencies, and all that fun stuff again to make this ride safely without running super rich. Some reason the 4 definitions RS uploaded arent found in that folder. I can open the Big maps and flash that just fine which is like the 8200000 but as a definition its not recognized. Think its just not compatible with 1.29a? Slater I got your PM but no email. I also checked my spam and no go. What version of ECUF are you using? |
I was able to flash his big map for my 06. I had to manually place the definition in the folder to get it to work. Have you check your directories yet (rom directory & metadata directory)? My rom directory shows it reading from the definition file RS made.
green did u try my way
Originally Posted by jakermeister
(Post 9880126)
(Post 9883132)
http://s1210.photobucket.com/albums/...=MetadPath.jpg
Originally Posted by ryancb
(Post 9883743)
I just checked and I did send the email. PM me your email again and I will send it when I get home again or igive me an alternate email.
I'm running version 1.42 with a 1.3u tactrix cable. I don't understand why it doesn't work for you. It's been running fine for me. |
Hmm, maybe its just 1.29a I want to try 1.42 but Im worried Ill lose functionality again. I dont want that considering Im going to be doing some MAF scaling soon.
Speaking of that we have to keep in contact more if youre going to be messing with the MAF too. They figured it out in the past, we should be past this problem by now. On the way back from work I might try some out. Have you tried any? |
| All times are GMT -7. The time now is 06:06 AM. |
