4B11 specs
Old Jan 22, 2010 | 01:22 AM
henryDgreat's Avatar
what happened to this sticky?
can X turbo pipes and stuff be directly bolted on a 09 lancer?
Old Jan 11, 2011 | 07:59 PM
GTS08's Avatar
Now im confused I boosted my GTS 2.0L engine any idea of any connecting rods for my need of boosting some more psi? also do you guys think It would be enough to just change the pistons and leave the stock connecting rods? I really want some more boost since I did 270 whp @ 6 psi , I wonder if there would be a huge difference on higher boost
Old Jan 18, 2011 | 11:24 AM
GTS08's Avatar
Ok I have a.doubt this means that if I turbocharged my 2.0l lancer 2008 I would only need to buy forged pistons because,the stock ones will hold on?
Old Jan 18, 2011 | 11:25 AM
GTS08's Avatar
Ok I have a.doubt this means that if I turbocharged my 2.0l lancer 2008 I would only need to buy forged pistons because,the stock rods will hold on?
Old Jun 19, 2011 | 08:52 PM
Ghilversumtuner's Avatar
Cool Can I fit this forged stroker kit on my 08 lancer es 4b11 engine
I was wondering if this forged stroker it can fit and work perfectly with my 4b11 engine 2.0l. HKS Stroker Kit Mitsubishi EVO X 4B11 08-10 or which forge stroker kit would be the best bang for me buck. would much appreciate the feedback +=
Old Dec 7, 2011 | 02:38 PM
nick9g4b1's Avatar
can we fit the BC 272 Stage 2 EVO cams + springs/ retainers?
Old Dec 8, 2011 | 01:13 PM
LiX's Avatar
LiX
Evo X and NA cams are interchangeable, so yes they will fit.
Old Dec 10, 2011 | 07:08 AM
nick9g4b1's Avatar
thanks for the response, bro. one more question: do I need to modify anything else in order to have the cams properly work with no problems, no CEL's ect.. LMK.
(I have a '09 LANCER ES, I'm shocked the EVOx cams can work.) +1
Old Dec 10, 2011 | 07:55 AM
LiX's Avatar
LiX
BC Stage 2 cams are too much aggressive for NA. I wouldn't recommend it installing them unless you go turbo.
Old Dec 10, 2011 | 07:59 AM
nick9g4b1's Avatar
Smh. That's what I was planning on doing, staying all motor but upgrading internals and all. If not 272, is there anything other cams I am able to use? All in all, any other engine upgrade? (I'm the "noob" when it comes to ENGINE performance - I appreciate the help, bro!)
Old Dec 10, 2011 | 08:05 AM
LiX's Avatar
LiX
Well, OEM Evo X cams will be safe improvement I think.
Old Dec 10, 2011 | 08:36 AM
nick9g4b1's Avatar
again, thanks bro!
Old Dec 10, 2011 | 08:45 AM
LiX's Avatar
LiX
again, thanks bro!
Tuning will be required after you install them. Don't forget that
Old Dec 10, 2011 | 08:59 AM
nick9g4b1's Avatar
Won't forget, but will I see a difference with the OEM EVOx cams? If I did go with the 272 cams, what will be the problem? Slower take off's or.. .. ..
Old Dec 10, 2011 | 10:48 PM
Panis's Avatar
Evolution X Cams fit but there have been some reported issues. I don't remember the details but I think it was something about the cam sensor busting so they were trying to fig out how to incorporate the evolution x cam sensor. Do some.more searching to find the details before u go through with it.
