4g94 JUNK??????????????
#34
the 4g94 is the best engine in the oz it'll make up to 250hp with out a head swap but if u swap the engine I recommend the 2.4 liter from the ralliart wagon it's more reliable then the 4g63 that's in the evo and is able to handle more power
#38
4g69 is a semi-open deck version of the 4g63 (as don carbone mentioned, larger coolant passages), with a larger bore. all other dimensions are identical, and all internals are interchangeable minus the pistons, all it's missing is the ports for oil squirters, but the channel is there, and just needs to be drilled and tapped...mitsuorder made like 800hp on 4g69 block with a 4g63 head...it's not the block that's weak it's the parts inside...stock 4g69 pistons have narrower ring lands, and are higher compression...300hp is doable with a bone stock 4G69...all it takes is head studs...I'm living proof.
#39
4g94
The DRAGON LADYS MOTOR Want to Run 4G94
I am the Dragon Lady I have many Lancers
and I love to go Fast
I have a 4G94 OX Rally and I will Run your Honda or what ever you have
If my 4G84 Can bet a New Camero I think i Can bet what every you have
its all in how to build the Motor Over Bor the Block 0.40 over ttttthe right pistons
Custom Mod Trans 5spd. headers with cat back free flow no Cat
wanna Race 2grand or Pinks
Dragon Lady
philcray (Jan 20, 2023)
SmurfZilla
74
Jul 30, 2012 02:37 PM
Demon_ni2
Lancer Aftermarket Forced Induction Tech
Nov 20, 2007 11:52 AM
