-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   any 04's with RPW header? (https://www.evolutionm.net/forums/lancer-engine-tech/121800-any-04s-rpw-header.html)
rallyme Feb 8, 2005 10:54 AM
'im looking into buying the rpw header friday, but does it fit? i can't tell if my stock dp bolts to the cat (not precat) or is welded to it because of the heatshield in the way. sorry for being too lazy to crawl under there and check, but i don't feel like laying in the mud at the moment,maybe in a few days when ground dries up. so how about it, any o4 guys running this header?
Mitsiman Feb 16, 2005 07:34 PM
The RPW kit will bol tup to the stock cat converter position if you get our cat converter with the kit or otherwise you will need to welding a small section on to join it to the one remaining cat converter on the car
TeAmEmPeRoR Feb 26, 2005 10:39 PM
eh? Sorry Mitsiman, I didn't quite get that.
So, if we get the cat convertor from you guys with your header kit, it will bolt right up, but if we stay with our original cat convertor, we will require welding?
Mitsiman Feb 27, 2005 04:44 PM
YEs in a nutshell
