-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   Dumb Question: OBD II READER: Don't Laugh (https://www.evolutionm.net/forums/lancer-engine-tech/150588-dumb-question-obd-ii-reader-dont-laugh.html)
03RedLancer Jul 26, 2005 01:09 PM
My father has given me an OBD II code reader; due to an exhaustive list of warranty bulls**t I have been chasing an SES light on my own for 4 months. I have a complete list of codes and I'm very capable as a mechanic. The car has had a complete tune-up.
I'm pretty sure the light is on due to a small, C-curved pipe running from the manifold to the exhaust: It is barely attached at the manifold. Until I patched it, it also had a hole. Just to be sure, I want to see codes.
Where do I plug in the code reader on the Lancer??? Sad but true, I have no clue!!!
(I know you're all laughing LOL LOL LOL)
Alchemist Jul 26, 2005 01:14 PM
to the right of the steering column, actually closer to the center console under the dash. There are two connections and you'll want the one that runs left-right. Just stick your head under there and you'll see what I'm talking about.
Good luck with the code hunting {thumbup}
03RedLancer Jul 26, 2005 02:13 PM
OMG Thank you so much. I had a feeling it would be in the dash. My last car - it was under the passenger floorboard. I have no kind of manual or anything so all my info comes from these forums.
HobieKopek Jul 26, 2005 05:58 PM
That's a handy tool. If you have an exhaust leak that could definitely trigger a CEL/SES. If it's that simple, consider yourself blessed. :lol:
GreedMOTO Jul 26, 2005 06:08 PM
Wasn't the standard set for all cars after 1996 to be OBD II compliant and have the access port in roughly the same spot (under the dash, driver side, off to the right)?
-Vince
HobieKopek Jul 26, 2005 06:47 PM
Iono about access point. Maybe his other car was OBDI. Guess it depends what make/model/year.
BADEVO Jul 26, 2005 06:49 PM
An 03 with OBDI ?? Do they still make OBDI cars? I thought 96 or 97 and up was all OBD II? I am asking not saying..........
HobieKopek Jul 26, 2005 06:51 PM
That was regarding the location of the port in his previous car. And yes, you are correct that all '96 and up cars sold (through normal channels) in the US are required to be OBDII compliant.
livelyjay Jul 27, 2005 11:51 AM
Damn right they are, but there are manufacturers that add in a crap load of other monitoring items that you need special software to read, but the regular OBD2 items are still visible. Ford is one of these.
Post up the code you read and we'll be able to help you figure out how to fix it.
