-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   HELP!Can't tell speed,temp or gas!HELP! (https://www.evolutionm.net/forums/lancer-engine-tech/348719-help-cant-tell-speed-temp-gas-help.html)
ed7232004 May 31, 2008 09:47 AM
Guys! i took out my cluster(dashboard) and put LEDS in it~ it looks great! here s the worse part, i didn't know i wasn't suppose to take the NEEDLEs off from the guage face. And when i put them back, they all messed up! now i can't even tell how fast am i going, or gas or temp! please if anyone knows how to fix that let me know! do i need to buy a brand new cluster or i can fix it within couple hours??! thank you !! :mitsu:
by the way i have an 02' LANCER
Lancer8806 Jun 24, 2008 02:51 PM
Sounds like they are uncalibrated. You'll probably need a new cluster. Your local junk yard will probably have it.
gabeamaro Jun 24, 2008 02:54 PM
well its only a lancer so it cant go that fast so its not a big problem
CaliMR Jun 24, 2008 02:55 PM
Try taking off the needles while it is off and all the gauges are zero'd out, then put them on pointing toward empty/0/cold whatever. It should at lease get you close.
