intake manifold
I found this intake manifold looks great not plastic and smooth inside instead of the rough inside of the stock plastic manifold here is the link. the only problem i see is its for the EVO X will it fit on the GTS? http://www.maperformance.com/maperfo...x-im_rev2.html
This is a porting / polishing service that we offer for the stock intake manifold sir :) We can absolutely do the same for your GTS!
Edit: I apologize I might have spoken too soon, is the stock intake manifold on the GTS plastic? |
Yup the GTS has a plastic intake manifold.
and the lancer intake mani is different from the EvoX's, at least im VERY sure....i think the lancer intake manifold goes down further than the evos
So it wont fit on the GTS? I wonder if we can take the plastic manifold off and smooth the inside with a dremel tool or something.
so the evo x intake mainfold wont fit a gts? I wounder if we can take the plastic one apart and smooth the insides our self that would be better than nothing.
plastic ones are made to be more smooth then a cast aluminum or any metal one that you can buy.
