-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-198/)
-   -   Tsudo Header-back Exhaust Fitment. Help! It's leaking. (https://www.evolutionm.net/forums/lancer-engine-tech/522213-tsudo-header-back-exhaust-fitment-help-its-leaking.html)
EyeDreamt Oct 29, 2010 07:23 AM
So I installed my tsudo header-back exhaust last night, and while most of it lined up decently, the downpipe seems to have a gap between it and the header. Its bolted down as tight as i could get it, but alas, i can see the gap from above... however the sides are connected well.
Anyone else had problems with the tsudo header-back? I'm thinking of just using the stock down-pipe and then the bolting the Tsudo to it... but not sure if it will fit... I'll take any suggestions.
Evo10HKS Oct 29, 2010 12:56 PM
hows it sound? any pics or vids or any notice in performance?
EyeDreamt Oct 30, 2010 07:06 AM
Got it all fixed up. The gasket that came with it wasnt fitting right so I used the stock one per a 9glancers forum member's suggestion, as well as straightened the opening of the pipe and it turned out great.
It sounds good. Some might consider it a little loud, and it really is if you get on it, but I love it. Not to mention you can always put the silencer in if its too loud for ya. Or if you buy the kit and don't like the loudness, take out the straight pipe and just use the muffler that comes with it.
