need help with my 4g94
I just bought a 2002 lancer oz rally and was wondering what's the first thing I should put in to my motor other cold air intake ??? And suggestions ???
what are the miles on the engine? i would start there and make realistic goals for what you want out of the car.
It has 118,000 miles its not that bad what do u think its best to start off with ?
Originally Posted by Dank_oZ rally02
(Post 11526518)
The intake isn't a bad place to start, get a nice clean K&N filter. An exhaust system probably next, then I could see myself wanting to next address the handling and braking of the vehicle. Short of a turbo, you aren't going to find parts available that are going to do much as far as the power output is concerned, but by addressing the suspension and brakes you can raise the enjoyment factor of the car quite dramatically. I've done just about everything you can possibly do to an OZ Rally, and more, and for me the most enjoyable mod were my TEIN coilovers. |
I'm going to def do that thanks..I've been told before that I would have to custom make make my turbo kit is that true ?
(Post 11526521)
The only turbo kit to my knowledge for the 4G94 is Road Race Motorsports' kit which is in the opinion of a lot of Lancer owners overpriced for what you actually get. This kit includes a 16G EVO 3 style turbo and usually gets most users just over the 200hp mark installed at their recommend 8psi. |
I don't think you are near ready to put a turbo on it.......
(Post 11526518)
Just to give you a idea....
I added a OBX exhaust 4-2-1 header with wrap, Cold Air intake, Upgraded ignition coils and NGK spark plug wires, Alum RRM Underdrive pulley, Megan Racing full exhaust. Very small if any noticeable power increase. Sounds bad ass though. I might be up to 130 from 120 |
I have a 2004 oz rally and wanted to know how to push more boost. Can I upgrade my internals to rrm and I mean everything they have for engines to make it stronger.
