-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   mil eliminator install Q's (https://www.evolutionm.net/forums/lancer-engine-tech/95981-mil-eliminator-install-qs.html)
terrible1 Aug 27, 2004 08:51 PM
i just put in the bigjoshracing mil eliminator and put the wires about 2" away from the 02 sensor is that to close?where did everyone put theres?
terrible1 Aug 28, 2004 09:41 AM
come on i know somone else has put one of these one.
GreenPsycho Aug 29, 2004 07:17 AM
actually, reread the directions, it says 2" away from the connector, and thats where i put mine
terrible1 Aug 29, 2004 07:49 PM
did yours work cause mine did not,but i dont think that would make a differance would it
GreenPsycho Aug 30, 2004 05:07 AM
i have to drive more before i find out. i'm not sure how much of a difference the location would make, but i would try reinstalling it cause maybe your wires don't have good connections or are touching each other or something
GreenPsycho Aug 30, 2004 08:37 PM
nope, my light came on today, as i was gunning it onto a highway. ah well, guess it doesn't work for everyone
tweakdsm Aug 30, 2004 08:40 PM
might be the same, i installed mine under passanger seat. there is an opening for o2 sensor same as in lacer i belive.
crnesst Sep 6, 2004 05:00 PM
Ok, i want to know how you guys hooked up your mil. The directions show different colored wires then what is actually on the car. When I looked at the wires on the o2 sensor there were 2 black, 1 white, and 1 blue. The directions I got have completely different colors so I want to know what wires you connected and if you could show me a pic I would greatly appreciate it. Thanks
TURBOit Sep 6, 2004 07:36 PM
screw that, jut pull your CEL bulb! it's free and a lot easier.
LancerOZ Sep 6, 2004 08:26 PM
Can someone with a _working_ mil eliminator post pics of the part installed? Or can someone link me to a thread with a picture if it's already been created?
- Jason
Alchemist Sep 6, 2004 10:19 PM
I took a pic and then my camera died, can't tell if it's useable. here's the wiring, though.
Leave the black wires alone
white>grey>MIL elim>grey>white
blue>green>mil elim>black>blue
I don't think it matters where it's installed, but a couple inches from the sensor is more convenient, and that's where mine is. 15K miles, CEL only at startup, like it should be.
If you have one that doesn't work, check it with a mutimeter (I got mine for $4 at my local parts store, works like a charm). If it's broke for sure, and BJR won't replace, cut it open and see if the guys at your Radio Shack can hook you up with the stuff to do it.... I can't imagine it more than a couple resistors, and they're notorious for not working. Bring your multimeter to check the parts.
