Warming your car in the morning.
I have a remote starter and usualy let her run for about 10 min. My remote starter will tell me the temp inside my car so i usualy go by that. Someone said they turn on the rear defroster before they shut the car off. If i turn mine on before i turn my car off then when i turn my car back on my defroster is off. Is there anything i can do so it stays on?
I have the DEI Viper 791XV. I love it. You can adjust it so that even the wind can set it off, but my parents didn't like it. You can add as many sensors as you want, they make different kinds such as a field, shock or tilt sensor. I added the tilt sensor to protect rims.
Has anyone ever heard that allowing the car to warm up for too long causes the piston rings to deform?
An auto service teacher I once had said to only let the car warm up for 30sec-1min at most, then drive gently until the car warms up. This allows the piston rings to gradually warm and expand under a range of RPMs and this helps avoid leaks in the future.
