custom built CAI for a 02 OZ?
Old Jan 22, 2007 | 04:36 PM
drucea's Avatar
probably, the one I went to had two different ones, neither were even close.
Old Jan 22, 2007 | 05:26 PM
Majuljo's Avatar
yeah ill check both ideas out. i was talking to my dad about it and he doesnt liek that its all cheap!! lol he probably thinks its a scam which i kinda believe thats why i am kinda leaning towards the autozone idea.
Old Jan 22, 2007 | 06:46 PM
drucea's Avatar
thats why I said don't get the whole bomz intake. It is cheap, because its 2 small pipes welded into a 90 degree angle which isn't the best design. But the adaptor is just a plastic piece allowing you to attach a filter or piping to the MAF. Plenty of people are using that intake fine, I just don't like the look or design of the whole thing. Whatever you choose, you can't really go wrong, as long as you don't touch the honeycomb inside you MAF sensor
Old Jan 22, 2007 | 08:31 PM
Majuljo's Avatar
yeah i think what im going to do is just buy an MAF adapter and then put the K&N filter on it. but i get the main point
DONT TOUCH THE HONEYCOMB!!!
Old Jan 23, 2007 | 08:33 PM
RedOz03's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=242667 dunno if that helps you any.
Oh and beware of the kits on ebay with the mandral bent tube in the pic. i ordered a kit just for the tube and got the crappy kit with the welded 90* tube.
Old Jan 23, 2007 | 10:41 PM
Majuljo's Avatar
that actually helped a lot. i think ill do what that guy did because i like how his turned out and i can still use the stock tube. and if i wanted to upgrade to a metal tube later on.
Old Jan 24, 2007 | 08:07 AM
RedOz03's Avatar
Glad it helped.
Old Jan 29, 2007 | 12:57 AM
Puerto_reCOn's Avatar
My pipe is REALLY FAT and i've pulled unexpected wins. my advice is buy a ebay cold air intake piping and a K&N filter....that's what i did.
Old Jan 29, 2007 | 07:59 AM
CF-Ninja's Avatar
most important thing I can think of is to make sure that the portion of the tube around the MAF is the same diameter as stock. A RA guy a while back had a custom setup that was about an inch larger than stock where he mounted his MAF and it ran really bad because it was not registering proper airflow.
Old Jan 29, 2007 | 05:45 PM
Majuljo's Avatar
well i went to pepboys the other day and they have everything there to build one yourself. even pipes (dont know if it would fit my car but they should) anyways i was thinking of just going there instead of the whole ebay thing. i feel safer lol. but awesome ideas.
Old Jan 29, 2007 | 05:46 PM
drucea's Avatar
if it fits, go with it.
MR_EVO8
Jul 3, 2011 05:51 AM
Nomad4g63
96
Feb 14, 2008 09:42 AM
c-rod
Southeast Region
Jan 25, 2008 07:31 PM
BigAeVo
14
Mar 6, 2006 07:12 PM
cannyboy
Mid-Atlantic Region
13
Oct 4, 2003 03:34 AM
