Straight Pipe vs. Catalytic??
I changed the headers and down-pipe on my 06 OZ leaving a gap between my mid and down-pipe where the old cat was. Im going in tomorrow to fill this gap but do you guys think i should put another cat in or just straight pipe it? Ive heard straight pipe is more horsepower but ive also heard that cats save you a lot of gas mileage
Anyone know the difference in mileage with or without a cat?
What do you guys think i should do?
thanks!
thanks!
the cat really dont matter, its what the o2sensor reads to mix the air/fuel ratio. but a high flow cat would be better, you cant mess with these newer cars exhaust too much like you can on the older cars since its all about computers now days
I was perfectly happy with a gutted header and a high-flow cat, but you could also get the straight pipe and leave the header cat stock.
To each, his own.
It really depends on how you're set-up is right now. While freeing up the flow of your exhaust is ideal, there's a threshold in terms of backpressure where too little can do damage to your horsepower.
Think of a garden hose with water, where the Cat converter would be like a nozzle or a kink in the line, there's a lot of pressure and not as much flow. Take out the kink or nozzle and now you're pretty much free flowing. Now take the same amount of water and use a fire hose instead, which is pretty much whats gonna happen with an upgraded exhaust running a straight-pipe.
Even for me, a high-flow caused me to lose power in the low-end of the power band. Unless you performed heavy intake mods, ported your head, and all that jazz, freeing up your exhaust with headers, a high flow cat, and an aftermarket exhaust would push that backpressure threshhold... Different story if you're turbo'd though =P
