Which air vent leads to ac evaporator?
Old May 17, 2012 | 01:28 PM
Heebs 09gts's Avatar
I have a product that you spray into your air vents and the foam will travel into the evaporator and clean it, then it will drain out the bottom.
Does anyone know which air vent will lead directly into the evaporator, or which vent would be best to use. Ive searched and the best i could get is, either the centre or passenger side air vent. Any help would be greatly appreciated, or what I should search for to lead me in the right direction.
Any helpers get a
Old May 17, 2012 | 02:05 PM
foxbear2277's Avatar
Centre vents are always the most direct point to the evap; as the evap is located in the centre of the dash. Most kits will have a long nozzel that can be put a good distance down the vent, id ensure ac button is pressed to ensure evap is exposed. Good luck
c08
Oct 1, 2016 05:07 PM
Nic Money
Mar 22, 2012 12:20 AM
bsmart82
Aug 23, 2010 12:28 PM
EVO8LTW
Feb 20, 2008 05:56 PM
TearItUpSports
AEM EMS
Aug 1, 2004 10:39 PM
