What else do i need for piston install.
Old Jan 25, 2004 | 09:31 PM
imapunkclaimer's Avatar
I Have the: 4 Pistons, 4 Rings, 4 Pings and a bunch of other circular crap. This guy said I Need new bearings and gaskets. Is this true? do i have to spend like 700 bucks on this stuff? What did you other turbo guys end up doing and who installed the pistons for you?
thanks for the help.
-Marc
Old Jan 25, 2004 | 09:35 PM
oh and this guy said 1600 for the piston install!?! thats like so much money geez. how much did you guys have to pay?
Old Jan 25, 2004 | 10:29 PM
Higgity Hank's Avatar
Unless you know EXACTLY what you're doing, pay someone. Yes, you need gaskets. Bearings isnt' a bad idea either. And by 4 rings, I hope you mean a complete set of 16 rings (4 first, 4 second, 8 scraper, 4 expander) Not sure if we run a floating or pressed pin, but I'm going to assume pressed, which should also be done by someone with some know how. You've also got to break the glaze on the cyclinder walls, etc. etc. etc.
Basically, if you need to ask these questions, I'd suggest you pay someone else to do the work. A piston job isn't a simple bolt on. It's serious business.
Old Jan 25, 2004 | 10:36 PM
how much would the gaskets and bearings cost? and do the people who do the install buy and put them on for me?
Old Jan 26, 2004 | 01:45 PM
jamie's Avatar
labor to have my je pistons inst re install turbo and have the head machined and valve checked and 3 dyno pulls plus wideband on dyno was 1300 money well spent.
Old Mar 17, 2004 | 11:07 AM
spydervenm's Avatar
does anyone know how much would bearings cost?
Old Mar 17, 2004 | 12:31 PM
500-600
Old Mar 17, 2004 | 01:21 PM
JDM_FeTiSh's Avatar
From: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
if ur putin new pistons.might as well put new gasket. n sh*... dont do it urself if u dont know what ur doin.. n u might need torque to yield bolts. if they came with car.
Old Mar 17, 2004 | 01:53 PM
TURBOit's Avatar
new head gasket, head studs, and head washers are MANDATORY
with the JEs you should have 2 piston rings per piston, and 1 oil ring per piston, thats 12 rings altogether
i paid 970 to have my turbo kit removed, the pistons placed in, and everything back together
i would get new connecting rod bolts from mitsu too, dont want your rods fallin out, what other gaskets are there, maybe intake and exhaust gaskets, but thats it
iv ehad my engine rebuilt 2 times, ask me anything
