momo evo steering wheel questions?
Old Feb 7, 2004 | 10:09 PM
TeamNeXusOz's Avatar
to the people who have installed it on the US lancer...how hard was it to do?...i will hopefully get mine this week...is it something i can do bymyself?...or is it going to cost me an arm an a leg to get installed?
Old Feb 8, 2004 | 12:52 AM
ghostrider's Avatar
Piece of cake. Get the right sized hex wrench and a something small to use for a breaker bar. I've gone over the install process in detail so run a search!
Old Feb 8, 2004 | 02:28 PM
JWERNER24's Avatar
In Timeout
NeXus - where did you get yours? I've been looking for one for a LONG time...
Old Feb 8, 2004 | 02:34 PM
Dood...i lucked out...guy is selling it to me for cheap......so where does the hex go?...should i unplug the battery?...
Old Feb 8, 2004 | 04:53 PM
IILANCERII02's Avatar
what happens with the airbag once you install an aftermarket steering wheel?
Old Feb 8, 2004 | 05:35 PM
JWERNER24's Avatar
In Timeout
its not really aftermarket... its the stock Evo one. It has an airbag so it'll work just like the stock lancer one w/ an airbag
Old Feb 8, 2004 | 05:51 PM
ghostrider's Avatar
I'll write it up again and hopefully this gets stickied this time around:
1. Unplug negative terminal - this is more for safety in case your airbag decides to deploy while you're unhooking/rehooking the wiring.
2. Turn stock wheel so you can see the panel that pops out.
3. Remove hex screw.
4. Unhook two connectors; one for horn, one for airbag.
5. Line your wheels up STRAIGHT before removing stock wheel.
6. Remove steering wheel.
7. Reverse directions and enjoy.
Old Feb 8, 2004 | 08:13 PM
what do you mean by turn stock wheel so you can see the panel that pops out?
