HELP!!! RRM ECU Vacuum hose
Old Jun 23, 2004 | 04:12 PM
EMERALD MOON's Avatar
OK im intalling the rrm piggyback and im not sure which hose to cut, I see the fuel regulator (the little brass diaphram) but there are two hoses coming off it, one on the top and one on bottom, which one do I "T" into??
Old Jun 23, 2004 | 06:16 PM
bump...anyone?
Old Jun 24, 2004 | 08:40 PM
WADADLIG_OZ's Avatar
do not cut the vacuum hose on the car.
Cut a small section of the RRM hose supplied and connect that end to where the vacuum hose from the FPR runs to then use the other side of the T to connect the FPR vacuum hose. Last but not least connect the PB vacuum hose to the bottom end of the T.
This has been covered in the PB reviews. Check them out. I think one is by Livelyjay.
WADAD
Old Jun 24, 2004 | 09:37 PM
blackmantis's Avatar
the one closest to the top that runs to the intake manifold.
