Fog Removal from Headlamp?
Old Aug 9, 2004 | 08:58 PM
kromix's Avatar
Installed HID's tonight and a little bit of water got in there somehow there is a little bit of fog, will it go away by itself? If not, any1 have any suggestions how to get it out of there without removing the headlamp or bulb... heating it? cooling it? Let me know, im not good with that kinda stuff.... Or will it go away overnight and I am being dumb?
Old Aug 12, 2004 | 10:27 AM
ozracer4's Avatar
i was wondering this too. bump for info.
Old Aug 12, 2004 | 10:44 AM
h8yourv8's Avatar
Take the headlight assembly out, stick it in the oven for about 15minutes preheated at 225 degrees. Pull the lamp apart and let it airdry. While you've got it apart you could black out your headlights too. Then just seal 'em back up, stick 'em in the oven and push them back together. Mine had mosture in it and I figured it would eventually just go away but after about 2 weeks I figured I'd need to fix it myself.
